Anyone else unable to use lossless audio with AirPods Max (USB-C) on iOS 18.5 beta? Connecting via the included USB-C cable to iPhone 16 Pro Max disables Bluetooth and wired audio doesn’t work. “AirPods Max USB Audio” doesn’t show up either. Reboots and resets didn’t help.
You’re not alone.
I’ve seen several people on Reddit reporting that Lossless Audio isn’t working with the USB-C AirPods Max after updating to iOS 18.5 Beta 1.
I think you should report it to Apple through the Feedback app so they can fix it in Beta 2.
Thank you!!!
