Unfortunately. I switched to the beta as soon as I heard about Mirroring, but I couldn’t use it at all. iPhone reset, mac reset, but still Mirroring didn’t work.
I don’t use VPN
They are connected to the same wifi networks
They have the same icloud accounts
(Go to Mirroring and delete your Mac shown here, then try connecting again.) I haven’t tried this, has it changed with Beta 3? There is no iPhone mirroring setting in ‘AirPlay and Continuity’
I turned off wifi and bluetooth and it tried to connect again. I guess because the cable is plugged into my Mac. So I’ve done a wired connection test. It stays on the connecting screen again
I reconnected after forgetting the wifi, same thing again.
I need this feature. I hope this problem will be fixed. I gave feedback. If it is not fixed in macos15 beta 3, it will upset me a lot.
I believe Apple will improve this feature in macOS Sequoia beta 3. Some users on X have also reported that this feature has recently stopped working; personally, I cannot use the keyboard and iPhone screen, which is quite laggy on Mac.
I said, even if you are not within the EU, I think it affects you too, so you have to wait or what was said above, create a new ID with US origin, but I would recommend what Betaprofiles says, I would wait for its implementation or activation.
I can use iPhone Mirroring on my iPhone 15 Pro Max on iOS18 Beta2 and macOS15 Beta2 on M3 Max. However, after upgrading to iOS18 Beta3, I cannot use iPhone Mirroring. In the airplay settings of iOS18 Beta3, I I can’t see iPhone Mirroring. I tried going back to Airplay in iOS18 Beta2 settings and iPhone Mirroring appeared, but I still can’t use iPhone Mirroring on Mac.
Welcome LanNou82966, I hope they tell you something with the Feedback, although from experience they only receive Feedback, they never answer but I guess they will take it into account.
hi there, just simply toggle firewall setting, turn on firewall then quit Iphone Mirroing and connect again, if not just toggle and open again, it will work.
